Car screeching sound
    the car screeches and im not sure why that is... its every once in a while usually when its a cold start it'll go off then later stop. I know for sure its one of the belts, so does this seems like a certain belt needs to be replaced?
    my members ride page
    Its your belts.
    Most likely your timing belt but it could very well be your PS/AC belt.
      Tighten your accessory belt or its worn. If your timing belt is screeching you got problems.
        could even b the alternator bearings goin out. my brother is having the same problem with his car. screams when cold and once it gets hot it only screams when theres alot of load on it
          The timing belt will NEVER screech... if it does that, it's about to snap. The timing belt is pulled by a gear. The accessory belts are pulled by smooth pulleys. The pulleys are the cause for the screeching, since improper tension will cause the belt to slip.
          Belt slippage can be due to belts that are too loose or too tight. Cold belts squeal more than warm belts, since the rubber expands and gets tackier (for the lack of a better word) when it gets hot.
          Replace all visible belts. The timing belt should probably be replaced as well, but that is guaranteed to be a totally unrelated thing to this issue.
            Might it have to be with the heater? I get a similar screeching noise when the heater is on but when I turn it off, its gone.
            Stock 10th Anniversary Edition.
              i will most definately check out the belts to see what the deal is...i assume it is the ps/ac belt, because yea it'll stop abruptly when i turn off the ac . ill research to see if theres a diy for these belts .Thanks guys
                where did u come up with that 1 and worst of all u wrote that like u knew what u where talking about i know when 1 of my belts squeel its certainly not my timing belt think about it if ur timing belt was slippin to squeel the car wouldint run for long super jump the timing.u should b more careful when givin advise.
                  No way your Tbelt could make a noise like that since it has teeth
                  Probably slipping on the PS pump
                  wat?
                    Is your AC on? Even if you have it set to full heat, and the AC is on, it kicks the AC compressor on the remove moisture from the air (defogger), thus the squealing, most likely.
                      My alternator belt did it for a while whenever I started the car when it was cold.
                      As mentioned, check you PS and ALT belts to make sure they are not loose or worn.
                      As soon as I tightened my alternator belt the sound went away.
                      T-belts squeak?
                      3 CB's gone....
                      1 WK Overland....
                      Still miss the CB though......maybe one day.
                        well now i have a ricer exhaust (Fart CAN!!) so others might get the idea i dont have money and im just a wanna be
