Electrical problem? Or something else?
    Alright, heres the story.
    I've been driving around all day yesterday, without any problems. I drive from a fast food restaurant to Target which is less than 3 miles away. Park car, go in blah blah, I go to stick my key in and turn it, nothing happens, (the cluster lights don't come on and the car doesn't crank) it seemed like the battery wasn't connected so I looked and I played around with the cables and tried again. This time the cluster lights went of for a second but when I turned it all the way to start the car it went dead as before. I tried it one more time and the car started but it was idling way too low.
    I've got a 93' lx 5 speed
    Any help would be very helpful and greatly appreciated!
    josh
    1. If you played with the terminals and it came on that way check your connectors. After all it is an old car and those just might have gone out on you. (were they loose? massively corroded?)
    2. Test your battery make sure its holding charge (any auto parts store will do this for free unless you have a DVOM)
      same thing happened to me one day. turned out to be my battery terminals, change them ASAP. i didnt change mine for a couple of weeks and then my battery finally died because i had jump started it too many times.
      so save your battery and change them now
      Originally posted by slammed4thgen
      be risky, be smart, and most of all be creative!
        Battery terminals have been changed! it starts up great now without any problems! Thanks Nail and Busak!
        I thought changing the terminals would eliminate the idle problem, but it hasn't.
        It has gotten a little bit worse, stalling out when I have the clutch in, mostly when I take a turn but it won't do it every time though. Also when I have it in gear I don't have any problems.
        My paps says its the fuel filter, is he right?
          bumpage!
