is it possible to mix gearing from different trans codes to come up with something that would have lower gears for like 1,2,3 and then highway gears for 4,5 for better "take-off" down low yet still good fuel mileage?
Hybrid Trans??
Gearspeed does this.
You need to custom cut the gears. All the gears are not the same and yes gearspeed is a company.
As I said yea you can take all the gears and throw it in a transmission but will they mesh? Most likely the gearing sizes are cut differently so they wont mesh smoothly. This is why I recommend gearspeed since they are able to build hybrid trans and cut the gears to specification. I have pondered this and came up with gears wont mesh properly if throwing and F 5th into the h22a.
Originally posted by NAiL05As I said yea you can take all the gears and throw it in a transmission but will they mesh? Most likely the gearing sizes are cut differently so they wont mesh smoothly. This is why I recommend gearspeed since they are able to build hybrid trans and cut the gears to specification. I have pondered this and came up with gears wont mesh properly if throwing and F 5th into the h22a.
Watch out for those cement barriers
Originally posted by onefastbunnythis is possible without any custom work?
just stock h22 trans and stock f22 5th gear?
if so thats exactly what i was hoping to hear~If everybody you knew jumped off a bridge...the bodies would pile high enough to break your fall if you jumped after them.~
Project Deerslayer
UPDATE: DEER - 2, CB7 - 0
'93 EX 5-speed coupe
Short ram intake
Tenrai Himoto catback
Smashed front end
