Idle Problems...
    Idle Problems...
    I am haveing an idle problem. Evertime i give it gas or put it into gear it dies. d
    Does anyone know what could be causeing this problem.
    my ride page
    http://www.cb7tuner.com/vbb/showthre...24#post1781524
    weak compression
    fuel filter clogged
    injectors clogged up
    i hope mike can chip in and help me out.
    miss my turbo cb7
      it sounds like a ground wire to the wireing harrness is loose. there is a hidden one underneat of the thermostat. that was loose on my car and when i hit the gas it shook and the wire and wasn't making a clean contact so it would cut off
      the rebuild!
      http://www.cb7tuner.com/vbb/showthre...50#post2073450
