aem tru-power pulleys
    does anyone know how much power they would give.
    MRT: http://www.cb7tuner.com/vbb/showthread.php?t=95154
    like 5-7. its not much. the pulleys relieve the pressure off the crank pulley. if you get those pulleys, get a underdrive pulley too.
    miss my turbo cb7
      Be aware that people have had trouble with the underdrive crank pulley. Supposedly, it can cause oil pump failure (which can cause engine failure.) The accessory pulleys don't do much. The crank pulley is the one that gives the most gains.
      I've been running an Unorthodox Racing crank pulley for 3.5 years with no troubles. I've heard reports of other intelligent people that have had their motors fail, and blamed it on a pulley. The gains are in the crank pulley. The decision is yours.
      As for the accessories, they won't hurt anything. The power will be minimal, and you might not feel it... but those little things DO add up. There's no real downside, so I say go for it. Just don't run a heavy system, or your alternator won't charge your battery fast enough!
        i have the stock stereo in it. so i dont think it will be an issue. and you said go with u.r. do they sell the acc. pulleys too?
          Yeah, they sell complete kits. I'm happy with my crank pulley (got it used on ebay), but I never used the other stuff.
            Not really a fan of them. Honestly if you wanted power you can put the money elsewhere thats just me though. And deev covered the rest. You wont see that much HP as claimed on a dyno. Maybe at the crank but not enough to care about at the wheels.
              It depends on the motor. The RX-8 gained MORE than the manufacturer's claim when Super Street did it. Granted, for such a torqueless motor, any little bit helps!
              I've seen no such definitive tests with the H22 or F22, so it's hard to say how the increases go. It won't be much, but it'll be something.
              The good thing about the pulleys, aside from the potential oil pump failure and undercharging for a heavy system, is that there is really no drawback. You don't get a crappy idle like a wild cam, you don't get noise like an exhaust or intake, you don't have to go digging into the motor like pistons... It's not a HUGE gain, but it's probably the most power you're going to get for such little compromise.
              I DID feel a difference with my crank pulley. Not so much power, but more of a revvy feeling. The motor seemed to rev more easily, like with a lightened flywheel.
                i checked their site they also have stock diameter pulleys that are just lighter. all together you drop like 7.5lbs off just the pulleys. alt, ps and crank
                  The revvy feel is a difference but power wise I would not say its making much. It might give you a feeling of a slight boost but its not much to brag about. I had a UD pulley on my f22a6 also from ebay. Car revved better but I wasnt a fan of it personally. I would think if you have a pulley with the same diameter for the alternator and such the charging should be fine. Its just that most manufacturers go smaller so they can save more weight and crap.
                    i have the aem power pulley set. like they said not much difference mostly rev. but i have not had any charging issues yet either so they have been good. i just got a lightened flywheel and now my f22 revvs WAY more then it did before the pulleys and flywheel ....much faster too
                      do you know why the Crank pulley causes oil pump failure? is it something that you can fix by getting a better oil pump? or is it hit and miss, it happens sometimes but other times it doesn't?
                        when you change the crank pulley you also remove the "damper" which is built into the stock crank pulley, its just a rubber ring that minimizes vibration, fluidampr is the only company i know of that makes a damper built into their pulley. unorthadox dose not have a damper built into their pulley. its the extra vibration i believe that can kill the oil pump. weird tho because if i am not mistaken all honda engines 1.8 liter and lower do not have them only the bigger engines require this damper. this probably part of the reason aem chose not to make a crank pulley at all just the accessories
