DIY: Radiator Replacement
idk if anyone needs that diy, but its helpful. taking out the radiator is like taking off your wheels. you take off the top mounts, unplug the connectors, remove the transmission cooling lines and block them off, pull out the radiator. switch the fans to the new one. install it back on. mount everything into place. connect the trans lines. hook up the hoses. pour coolant in. let car idle for 5-10 minutes. and check cooling temp.miss my turbo cb7
