a6 intake manifold
    a6 intake manifold
    where is it acually located? is it that thing in between the engine and the programmed fuel injection. sorry, ttal newb.
    i think its the thing thats underneath the fuel rail.....i will need that for my a1. n e thing else? ive already got the pt6 and cam w cam gear. any sensors?
    1991 Lx coupe........traded now I have nothing lol
    wow this is a total noob question.....lolz. ill help ya out.
    the intake manifold is a part on our cars in which intake air gets sucked into the motor. basically the intake manifold is this.....
    the difference between the f22a1 and f22a6 intake manifold are the runners and the flaps inside.
    f22a6 intake mani
    its #4
    and f22a1 intake mani
    see how one has 4 holes and the other has 8?
    the 4 holes are alright, but for more airflow at 4,000rpm +, honda designed the f22a6 intake mani. what happens is when your driving down the road, the flaps are closed, as soon as you hit 4k, the computer sends a signal to a vacuum box, which pressurizes the valve on the side of the intake mani to open the flaps. when this happens it increases the amount of air entering the motor.
    what you need to convert to a6 mani is:
    pt6 (accord ex) computer
    vacuum lines
    the vacuum box
    intake mani
    egr plugs
    heres a nice diy
    http://www.cb7tuner.com/vbb/showthre...ntake+manifold
    miss my turbo cb7
      You the MAN QUICKANGEL
      DO u need a a6 head to work with the a6 intake mani?
      i should no this buy now but i dont
        That really is one hell of an explanation! That's the kinda stuff the guys who know the answers need to start doing here in the Beginner Forums. If all questions were answered like that, the "noob" level of this site would drastically decrease!
          i agree with you deev, it also makes it nice when there is no smart @ssness i think you informed him well without making him feel stupid. Bump for kindness
            That's how it should be. That's why people get banned for being jerks in the Beginner Forums
            When I started, I knew nothing at all. I wanted to hook a turbo up to a switch so I could have power and save gas. I learned. Everyone else can learn... they just need people to teach them, not belittle them! Responses like quickangel93's are exactly what we need. cleanjdm now knows just about everything there is to know about the manifold he asked about. Not only was his question answered very thoroughly, but now HE can help someone else with the same question!
              if you were still in cali, I could help you out. good luck bro.
                NO U DONT DANIELSAN!
                USDM [H] PiMP
                iP0P VTEC
                WhiTE B0Y!!!
                  no, the head is the same design as the a1. the only thing is different is the cam.
                  miss my turbo cb7
                    The A6 also has different valve springs, as the part numbers are different. Probably slightly stiffer. Not really a huge deal.
                      so should i get the springs and liftersfrom an a6?
                        you you should just get a head. much easier than taking everything apart.
                        miss my turbo cb7
                          Very true. F22A6 heads aren't very expensive.
                            haha look what i found, it kinda relates a little bit
                            F22a6 w/ H22a1 plenum and TB swap
