pt6 ecu upgrade
    The PT6 definitely will not be the cause of you failing emissions, it's not like this ECU automatically dumps more fuel in just for the heck of it. Its fuel curve is almost exactly like the PT3 until ~4900rpm when the secondaries normally open for the F22a6. Its only VERY slightly richer because of the slightly more aggressive a6 cam it's programmed for.
    Also: Just because you open up the intake and exhaust, thus creating a free-er flowing engine, absolutely DOES NOT mean the ECU will dump more fuel in, UNLESS you drive WOT all the time. An opened up intake means the engine has to do less work to pull in the intake charge at whatever given throttle position than before. And likewise with pushing out exhaust gasses. Driven under the same conditions (acceleration, throttle position, shift points, etc.....) an opened up intake and exhaust (given it's not TOO big) will always increase your mileage along with performance. The engine is using less power (heat) to move air and so more of it's potential energy can go to the wheels.
    The real question is this: Will you be able to keep your lead-foot in check or would you rather hear your intake and exhaust and feel the performance gains?? If you can't contain your natural desires, lol then sure, your mileage will go down. Drive it easy with these mods and I promise you'll see an improvement. You're making your engine more efficient.....decide how you want to see this efficiency displayed: through more GO, or more MPG....and then drive accordingly.
    My Member's Ride Thread
      ok that for the info.
      back at it again
        so not to sound stupid, im new to hondas, if u upgrade to the pt6 and have the intake, exhaust, h23 im and plenum, will this give you even better hp and tq or just take the limiter off?
          is pt6 better then p12?? pt6 is only good if you have the other component right?
          1994 Accord Coupe LX BPU
          1991 Galant VR4 #1395/2000 Sold
          1990 Accord EX 4DR Sold
          1990 Galant Base Model junked it
          1991 Accord EX 4DR gave away
