My Radiator Fans don't kick on at all. I also noticed the white fluid container to the left of the radiator by the battery has no fluid at all in it, is that right? Could it just be a fuse that's preventing the fans from coming on?
Radiator Fans
ok put some water in the revsivor tank, and open the fuse box on top. I no its a #15 fuse. LOOK on box, says FAN. Check it out**Blk Housed Slut Crew Member #1**
this happened to one of my fans and it was the motor it was no big deal to change and i got the motor at the junkyard for dirt so if its not the fuse you should check out the motor you can test the motor easy by taking it out and putting a - and + wire directly to ur battery that could also help u figure out if its in the wiring to the fans cause if u change the fuse and it dosent work but you hook it directly to ur bat. and it does its in ur wiring
BB6 2001 Prelude SH
Originally posted by Makaveli2kDon't be a sissy. Pull out, spit on the tip like they do in the porno's and get back in there.
=p
mine aint working either , and its a new one. well it did come on like twice when i first bought the car last month. but i replace it with the new fan from my old cb new rad.
1994 Accord Coupe LX BPU
1991 Galant VR4 #1395/2000 Sold
1990 Accord EX 4DR Sold
1990 Galant Base Model junked it
1991 Accord EX 4DR gave away
A quick way to diagnose the fans is to turn on the AC and both fans should come on or if you want you can directly jump the fan and it should come on. If it doesnt turn on with those methods could be a bad fan. Might wanna check the fan switch also could be bad. Another thing is that the fan wont kick on until your engine reads 220 I think or something like that. Your engine overheating? If its not I wouldnt worry about it. And as mentioned check your coolant level. The reservoir is usually partially full.
Originally posted by NAiL05A quick way to diagnose the fans is to turn on the AC and both fans should come on or if you want you can directly jump the fan and it should come on. If it doesnt turn on with those methods could be a bad fan. Might wanna check the fan switch also could be bad. Another thing is that the fan wont kick on until your engine reads 220 I think or something like that. Your engine overheating? If its not I wouldnt worry about it. And as mentioned check your coolant level. The reservoir is usually partially full.
also my temp is reading a little under the normal car temp should be.
disconnect the fan switch connector at the t stat housing, use a paper clip and jump those two connectors together, the fans should come on. if it does, then you got a bad thermoswitch. if it doesn't, well, then get back to us and we'll give you more info.The beginning of a new era............................
