Seafoam
    Seafoam
    Ok, so I've read the threads about adding seafoam to your gas, crankcase, and thru your pcv valve...sounded like it wasn't a bad idea to do, so I did it. Gas and crankcase first...no problems...next day I ran 1/3 of the bottle thru the pcv valve, jumped in the car, and it runs like crap! Running rough as hell now...thought this stuff was supposed to smooth out the way the engine runs? To begin with the engine light came on, first time since I've had the car...after driving around a bit and getting rid of all that white smoke I parked her for about 45 minutes, then off I went again. The engine light went off, but it's still not running as smooth as it was before adding this junk. I'm hoping that it's still just not burnt off good? So much for a smoother running engine...perhaps one of these days I'm gonna learn to leave well enough alone.
    Speaking of sigs... aRaKNiD, yours takes up more than my entire screen. Shrink it, or I will.
    did you change the oil?
    You need to change the oil after about 50-70 miles after some semi-spirited driving. If not, CHANGE IT NOW then report back
    ----------------My 92 Honda Accord LX---------------------- My 97 Nissan 240sx LE----
    NE GUYS, Buy the last of my accord parts
      I drove for about 4000 miles with seafoam in the crankcase... stupid... but thankfully it didn't do any damage!
        it may have only favored one cylinder a little too much maybe? most people usually pour it in off the vacuum line from the brake booster, it may or may not be better thats what i have always done and never had any problems
          putting it through the Brake Booster only favors 2 cylinders. The PCV distributes through it evenly.
            That is what I thought I had read somewhere...hence why I put it thru the PCV. I got something right...only the outcome was wrong...ironic.
