im looking to swap my f22 and get an h22 but i need to know can i use my same tranny or do i have to get a tranny from and h22. also what year prelude were ther h22s?
h22 ?
hey i see you don't have many posts..
but under the area where you need to ask a question their is an option to search for your answer without posting one.
type in h22 swap or h22 transmission and you should find tons of usefull info.
but to answer your question.. no your tranny will work although it would give optimal performance to get the h22 tranny esp, with lsd.
what honda did was design that tranny to fit the power band of the h22 verry closely, and makes for a better driving experience.."Self Renewed"
BTW are u actually gettin an H22 soon?...i mean, i think u should do more research and learn more of what your tuning with than not knowin wtf ur doing...cuz it'll come in handy soon. I mean there's alottttta stuff/ppl on here with alot of knowledge...so if anything im still learning before getting an H swap.
here ya go! http://www.cb7tuner.com/vbb/showthread.php?t=44639Last edited by Djmoua; 11-24-2007, 04:20 PM.
*Needs*
-New shocks
-Struts
-Drop
-Cleaning
-New Tires/Wheels
-New Window Tint
-Alot more lovin'
thats not what i am saying at all...
Take note that most h22 or f22 owners like the f22 long geared trannies for turbo swaps all the time. and at the moment i to have a f22 auto tranny, and rev it to 8 grand without a problem.
but in the end a shorter geared tranny allows the h22 to reach it's max power band alot faster and stay in that part for the whole WOT ..
I have never had any problems out of over revving any f22 tranny. I don't believe anyone else has either,, normally overrevving kills the motor first."Self Renewed"
tahaha my bad...im gettin sleepyy here.. and not thinkin right..but nvm what isaid then
*Needs*
-New shocks
-Struts
-Drop
-Cleaning
-New Tires/Wheels
-New Window Tint
-Alot more lovin'
Exactly. The F22 transmission is fine... but when you shift, you end up lower in the RPM range... out of thethe "powerband", or the RPM range where the motor makes the best power.
The F22 transmission will work, but it's not optimal. No harm will come from using it.
All F and H series transmissions (aside from the S2000 transmissions, and the Prelude SH transmission) will fit on any H or F series motor in our cars with no problem.
Originally posted by deevergoteExactly. The F22 transmission is fine... but when you shift, you end up lower in the RPM range... out of thethe "powerband", or the RPM range where the motor makes the best power.
SEEe? i didndt evenn nkow this for sure?!1..
*Needs*
-New shocks
-Struts
-Drop
-Cleaning
-New Tires/Wheels
-New Window Tint
-Alot more lovin'
Originally posted by DjmouaSEEe? i didndt evenn nkow this for sure?!1..
Spend a few years on these boards, and you'll see just how crazy some things can get...
O meant i didnt know that quote btw...sorry..now i DID read somewhere on here but i forgot...someone mentioned something about like the f22 tranny couldn't reach as far as the h22...so that's what i mentioned as well...cuz this member on here did have a nice cb too so i figured hey he most likely knows more than i do. Researched it to make sure...and it was right! But i am wrong about the tranny blowin up first...forgot about the engine hahahaha. SHOWS WHAT I KNOW! hah
*Needs*
-New shocks
-Struts
-Drop
-Cleaning
-New Tires/Wheels
-New Window Tint
-Alot more lovin'
We're all here to learn
I own the joint, and I'm still WAY behind a lot of people! I know a fair amount, but I'm far from an expert myself.
When giving advice, don't just regurgitate information, unless you have something other that the word of another tuner to go on. If you haven't done it yourself, or don't have a full understanding of the concept, don't just pass it around. It's better to keep all the info floating around as factual as possible!
lesson learned
...although..i feel like this is my thread hahah
*Needs*
-New shocks
-Struts
-Drop
-Cleaning
-New Tires/Wheels
-New Window Tint
-Alot more lovin'
