blower motor
    blower motor
    i need to replace mind i think it is not blowing heat or air. im going to check the wires today and see if it gets power. just bought my car and was wondering if anyone had this problem and how hard was it to fix. thanks in advance for the help.
    It's not too bad. You will have to pull the dash loose to get it done. And remove your glove box. It's the black box closest to the door on the passenger side under the dash.
    - Rob -
    92 Auto Sedan - "Rustoration"
    85 Toyota 4Runner
    1977 Kawasaki KZ1000/ZX6/10R Hybrid
    2008 HD 1200N
    2009 HD 883N
      Not entirely true. You can remove the glovebox, the support for the glovebox, the 2 bolts on the side of the dash, and you can move it JUST enough that the blower motor will come out. Be careful when you do this tho, and its not cold, you might snap the dash in half. Make sure first that its just not the connector thats loose, that happened once before, and i just needed to plug it back in. the m otor is also strapped in with 2 straps, connecting it to the heater core, make sure these to back on, or you will have problems... Get a new one, not a junkyard one. I got VERY lucky and found one that was no more then a month old at the JY, reciept was in the glovebox LOL! Otherwise i would have went new, they all have a ticking noise which gets annoying (hence why you buy it new) The blower motor comes out in a massive casing, (usually black or white) you'll need 10MM socket for most of it, 8MM/7MM for some of the other ones. Prepare to take at least half the day off to do this. Took me 3 hours just to get mine out.
      (also helps if you take out the passanger carpet, and remove the computer attached to the floor, gives alot more room to wiggle it out, and back in ( you may need to unplug it))
      If you need any help, just ask as i still have this fresh on my mind :P
      90 Accord EX F22a1 Auto R.I.P.
      2011 Mazda 3 Hatch 2.5L GS sport HELLO!
        Let me tell you something. When you're telling someone how to do something for the VERY first time, and you add in a caveat like this....
        It makes me think you're a fucking idiot. Especially when you say it trying to dispute what I just said. Whichi is easier, pulling six bolts out and getting the dash loose or removing it to replace it because you're too fucking lazy to do it right the first time?
        - Rob -
        85 Toyota 4Runner
        2008 HD 1200N
        2009 HD 883N
          thanks for the help guys.
            You got a fucking problem with my methods? I tried look in around for the other 6 bolts and couldnt find them, and it fucking worked. ANd i never had to reaplce the fucking dash, You got something to say to me, SAY IT IN A FUCKING PM.
            EDIT: Sorry for swearing, but he pissed me off
              Unfortunately PM's suffer a unknown disease called ERROR.
              Just knock it off.
              The OP found his answer. He'll follow either suggestions and he'll post back for more Q's.
              1996 Honda Civic LX 2009-2012
              2012 Kia Optima LX 2012-2013
                thanks for the help i pulled it down today and the fan was stuck.
