will this fit on my F20B SOHC vtec? if yes give a reply if you know it does. Dont reply if you dont know. the faster reply the better and the F20B head looks similar to the F23 head. Hope that helps?
F20B
This engine series was used in the CF4, CF5, CF9, CL3 Honda Accord and Honda Torneo from Japan. Also had a DOHC derivative (see below)
Specifications
* Bore × Stroke: 85.0 × 88.0 mm
* Displacement: 1997 cc
* Configuration Valve: SOHC, 16 valves, VTEC
* Compression ratio: 11.0:1
* Max power: 148 PS (109 kW) @ 6000 rpm (4WD), 150 PS (110 kW) @ 6000 rpm
* Max torque: 183 N m @ 5000 rpm (4WD), 186 N m @ 5000 rpm
H22/H23 intake manifold P14
F20B
Specifications
