do any of the lower model accords have taller gear trannys?
taller gears
Originally posted by 71_307
the accords starts off with 3.3(1st) down to .68 (5th) gear.
the h22 and h23 starts off with 3.3 (1st) down to .81 (5th) gear
you could tell how the gears are spread apart.
for example. if you slap a h22 in a accord with a f22 tranny, the f22 could push out 165 mph + proven already.
the h22 with a h22 or h23 tranny, would be lucky if you had enough rpm to hit 150 mph.
i know the newer h23/h22 can hit 150+ easy on their trannys.
basically from what i all hear, the f22 is a cruzing tranny. sometime for dd, and not much of racing.
the h22 or h23 tranny, and like killers, because you could see how damm fast it accels.miss my turbo cb7
why on earth would you want TALLER gears than the F22 already has?
maybe he has a ton of power!
gear ratios have alot to do with driving style, what your car is being built for, and personal preference.
Originally posted by wed3kbonneville?
sometimes cruisin on the hiway i wish i had a longer or 6th gear but i doubt the engine would make enough power to cruise at 80mph in 6 at 2 r.p.m.
