Underdrive Crank Pulley With P/W and Alter.. Pulleys
    Hi there, I went in these days to a local racing shop to check price but like every place it cost its higher than ebay any way, the thing is that I went to buy this 3 things, AEM Underdrive Crank, AEM Power Steering Pulley and AEM Alternator Pulley, the kit cames with the belts, but the seller told me if I put all 3 Pulleys I will get hard to start the car, because he said that the batery or alternator dont get insuficient charge to startup, Just he told me to put Just 1 or Underdrive crank or the 2 P/W and Alternator Pulley. What about you guys that have turbo's and racing cars wanna heard opinions. thanks.
    Honda La Ley - Clase y Mas...
    My Member Ride
    I got the power steering n crank pulley on my car. I also had the alt. pulley on too but i took that one off because my alt. was loseing power.
      if you have a stereo system or a lot of electrical accessories, you shouldn't put the alternator pulley on. it will burn up the alternator. later.
      Avoiding dirt at all costs
        If you don't have all that stuff, the alternator pulley should be fine. The only way your battery won't get properly charged is if the alternator is weak and failing already... in which case, replacing the alternator and using the pulley again would be fine.
        Does AEM offer an underdrive crank pulley now? They didn't for the longest time.
        I'm currently running an Unorthodox Racing underdrive crank pulley on my H22. It's been there for almost 4 years now, and many many miles. No problems at all. However, people have reported oil pump failure due to these underdrive pulleys. My personal experience says they're fine, but the experience of others is important enough to at least mention that risk!
        If you get an underdrive crank pulley, DO NOT get a cheap one! Unorthodox Racing, AEM (if they do indeed make one now), and... well... nothing else. I wouldn't trust any other brand to be properly balanced.
