Need help finding good camshafts
    Hey guys ya'll have helped me out before so i knew ya'll be the best ones to ask again. I was looking for a good set of aftermarket camshafts for my h23a. i gonna keep the accord as my everday driver and want a good streatable camshaft. Thanks for the help in advance.
    Check out bisimoto, I don't know if he does h23's but its always worth looking into. Then theres also delta regrinds.
    Originally posted by 92dm
    I was actually just being a smart ass, and not really contributing to this at all.
    VOUCHES
    Bought from: cb95spd
      yeah will defintley have to check them out
        crower also makes cams for the h23
        My Members Ride Thread
          Stage 1 is probably the best way if you still want to keep stock valvetrain and get a small kick. it will also be streetable and more friendly to your valvetrain. Stage 2 and up you have to start modifying other stuff.
            i dont have an h23 but i do have f22a1head and f22b2 block,...what cam wat be good for that situation?
            clicky the siggy!!!
            ARCADIA GREEN MEMBER #20
            AIM=SleepygreenCB7
            Yahoo=annamaineeak@yahoo.com
              a6 from what i understand
                wats an a6?
                clicky the siggy!!!
                AIM=SleepygreenCB7
                  from the f22a6 engine. The cam's a bit more radical then the f22a1 and a4 engine. Also, as Deevergote once stated...the f22 engine is Bisimoto's bread and butter. So if you are serious about your engine, I'd give Bisi a look see
                  ^^click it or ticket^^
                    The Bisimoto is the other option for the F cost a bit more but gives you power. Another cheaper option would be a Delta regrind.
                      Ok so i'll ask should i go with buliding up the h23a and go turbo but just with low boost this will be my everday car or sholud i go vtech and go all motor.
                        Do whatever you want. And since you say "vtech", you should probably learn a bit more about your options before you start spending any money.
                          Cause i'm thinking if going with the h22a head getting the type s cams and going with a 4-2-1 header i have read for a good street set up this works the best.
                            And yes i realize i made a typo it is vtec not with an h
