Sycrhomesh..
    Sycrhomesh..
    okay i been told the sychomesh is messed up in my car
    i read wikipedia, and i kinda understand what it means but i have no clue what it does in our cars ?
    okay
    can it be replaced? how much ?
    Ride: 2002 Lexus IS300
    You mean the synchros are messed up in your car? Or you put synchromesh in and it messed up your car?
      the Sychros are messed up
        Your transmission needs rebuilding.
        Gary A.K.A. Carter
        [sig killed by photobucket]
          i been told by slammed4thgen to
          change my Manual fluid to HONDA BRAND
          but idk if it will help since my friend that's owned HONDAS
          ALL HIS LIFE (he's like 50)
          drove it today and was amazed at the h22 power but
          he saw the downshifting to 2nd issue
          and told me it's the sychromesh
          but he didn't tell me if it can be fixed or nothing
            estimates?
            alot ?
              Originally posted by cvc7chris
              estimates?
              alot ?
              find a junk yard one for now
              wat?
                "Synchromesh" is the name of the synthetic manual transmission fluid developed and sold by General Motors.
                Synchronizers are the components inside your transmission that keep the gears from grinding when you shift. When they go bad, the transmission needs to be rebuilt.
                Changing your fluid to the newly improved Honda synthetic manual transmission fluid will help relieve the failing synchronizers and POSSIBLY give you a little more time with your transmission. GM Synchromesh works as well, but the Honda fluid is better for a Honda application.
                If your friend said the "synchromesh" was bad, then he has no idea what he's talking about. The fact that he's old and has driven Hondas all his life doesn't mean much. I've owned a microwave all my life, but I have no idea how it's put together, or what makes it work. My friend has been driving a car for 10 years... but she STILL can't tell you the difference between wheels and tires.
                Flush the fluid. Replace it with synthetic Honda MTF, or use GM Synchromesh. Just under 2 quarts should do it. If that doesn't fix the problem, rebuild or replace. Or deal with it. When I had my F22, my 2nd gear went. I just skipped it
                  When was the last time the oil in your tranny replaced?
                    probally a while back i getting to it asap
                    haha lol
                    well i think he said synchros or something
