Engine Temp Goes Up When Car Isnt Moving
    Well Yea When Im At A Drive Thru Or In Heavy Traffic My Engine Heats Up An Once I Start Movin It Goes Back Down Whats Wrong Wit It??? I Think I Mihgt Need A Thermostat?
    USDM [H] PiMP
    iP0P VTEC
    WhiTE B0Y!!!
    check your thermastat (sp?) and also is your fan coming on? you need to park it at your house start it up and let it get to warm and sit there and see if the fan comes on that might be your problem also
    Originally posted by jboyce
    i f'd this girl last night i hadnt seen in a while...used to be cute, but when i had her naked lying on my bed i noticed she had gained alot of weight and looked like a manatee rolling around on my bed.
      this is relly esay man
      u car is overheating
      why does the temp slimb up the not muving?
      easy no airflow is passing the raidiator
      once u get moving air passed by the rad
      so it coolllssssss
      yaaaayyyyy
      its ur fans bro lat8r
      Just do what PR CB7 said.
        Cool Ill Check That Out This Weekend
        USDM [H] PiMP
        iP0P VTEC
        WhiTE B0Y!!!
          happens to me often ur low on water and only thing colling it down in air...ask prnonvtec4u he was with me when it happened also u might have air in ur line not a real big deal though just add some water
          New & Improved 93 Accord EX Coupe
          what makes a man a man?
          Originally posted by ric3rboi23
          disrespect females, acquire currency.
            could be the thermostat stuck open... happened in my 3g. the car would only warm up if it was stationary, as soon as it got going, the thermostat would drop bottom.
            if it is your thermostat (could be the fans also) then DO NOT use an aftermarket replacement. Get a honda one. unless you really want the extra experience from doing the job twice
            RIP
            Bought from : LosiRacer2, h22anow
              Are you overheating?
                same thing happend to me. First stick to the cheapest fix. Check the water. Then if that doesn't help check out the fans. I had the same problem and i found that turning on the A/C would start my fan up.
                My Member's Ride Page (Do it)
                  Yea, it has to be ethier the fans or the thermostat. I had that exact same problem before.. It felt embarrasing too!. have you checked for leaks yet?
                  My Black "H"
                  AL Meet!?
                  //Secret G2I Lover, Shhhhhhh! //
                    If its not overheating and warms up to normal temp when idling but cools down when moving = Stuck open Tstat or low coolant level
                    If its idling and overheating - Check coolant levels and fans.
                      don't let it overheat. i can't stress this enough. the last thing you want is a blown headgasket from overheating.
                      the first thing i'd do is check the coolant level.
                      i'd also replace the thermostat anyway. it's like cheap insurance because the part only costs about $12.
                      let the car run for a while and see if the fans kick on. hopefully it's not one or both of the fans because they cost a bit more. later.
                      Avoiding dirt at all costs
                        One Of The Fans Are Broken I Started The Car An Only 1 Was Working It Got Really Hot But I Cut It Off An The Coolant Was Bubbling.. Imma Add Water An See What Happens Cause Its The First Time It Happened
                        USDM [H] PiMP
                        iP0P VTEC
                        WhiTE B0Y!!!
