kinda hard 2nd gear when downshifting ?
    kinda hard 2nd gear
    okay so when i accelerate from stop
    it worked GREAT all gears without any trouble
    but when im like in 3rd or 4th and want to put it in second it won't go in?
    THE only way it goes in if you do the "clutch and put it in 2nd" FAST!!
    otherwise it won't go in
    does it need grease or something somewhere?
    transmission works good so i doubt it's that
    any of ya experiencing the same
    Ride: 2002 Lexus IS300
    anyone ?
      if you're downshifting try a little gas before grabbing second and letting off the clutch?
        yea rematch and see if it helps
        Formerly 91AccordExR33
        11.68 @ 127mph
        417whp/375wtq
        Sold: 8/2016
          yeah gas kinda helps but kinda grinds
            synchros probably, although a good, strong clutch will help usually. cold weather and thick tranny oil will also make it worse.
              what's that? sychros?
              would a tranny oil change help ? my friend can probally do it
              i don't want to pay 100 bucks for nothing lol
              it is kinda cold but not too much
                SYnchros = Synchronizers. You can try using pennzoil synchromesh to see if that helps. But usually if its bad enough the synchronizers are going bye bye and you will be required to either rebuild or get another trans. its a common problem in older honda manuals.
                  damn
                  so if im running a h22a the tranny will be like a what? 97 prelude tranny? if it is that
                  and try what? and put it where?
                  my friend said it needs grease im like wtf?
                    Get your friend to show you what needs grease. The shifter might need grease, but I doubt that's the cause of your troubles. Do you have a short shifter by any chance?
                    The H22 came in Preludes from 1992-2001.
                    Pennzoil (or GM) Synchromesh is a synthetic manual transmission fluid that can help with failing synchronizers. It goes in your transmission. You use a funnel to put it in the transmission. You use your hands to tip the bottle to pour out the fluid. You use money to pay for the fluid. You get money from a job, or mommy and daddy.
                    Would you like to hold it yourself now, or shall we continue?
                      haha. So busy, and yet enough time to post up pictures of spoons.
                      Click for my ride thread.
                        Spoons are for feeding. You put food on them and then put them in your mouth. You remove the spoon before chewing so you don't hurt your teeth. Then you move your teeth around to mash up the food, and let it slide down your throat hole.
                          i had no idea wtf sychromesh was
                              too much time on your hands lol
                              Thanks BTW
