Foamy...You sure your using coolant? Either to fill it open the bleeder screw first. Dump the coolant in and air should vent through that opening. After that start up the car and let it idle until the fans come on. After that bleeding is complete. A low coolant level will cause normal -1500 rpm consistant fluctuations. Its common in hondas. Anothre thing could be IACV is bad or you got a vacuum leak. Idle problems can stem from a lot of things.
foamy???
The factory manual says to bleed with the engine off...not sure why people are being advised to do it otherwise.
Factory manual for coolant bleeding.2003 Maxima SE Titanium Edition
1993 Suzuki GSX1100F 136bhp
The way I do it I just open the valve dump the coolant in until its full. Shut the valve, start the car and let it idle until the fan comes on. I have had no problems with this method and it works all the time.
Like NAiL 05 said, this is how I bleed my coolant.
When the car is off and cold:
-Take off the radiator cap
-Top off the fluid and leave the cap off
-Open the bleeder nipple
-Watch the nipple and wait for a constant stream of coolant to come out (no bubbling or anything)
-Top off the fluid
-Close the cap and you're done
Some people like to leave the cap off and run the car until it's at operating temperature, you can do that too.
Also I've been told if you leave the cap off overnight the air works it's way out and when you look in the morning the level will be down, then just top it off.
Make sure your resorvoir is filled porperly also.
