im looking to upgrade my fuel injector's since a few of them are leaking and gone bad. so i am wondering is it safe to get 450cc injectors or just stick with another set of stock ones. I read that if you get larger injectors it will be harder to keep the engine idling correctly and they can also cause you to run richer. Well, i have a NA setup, so would i need to get a fuel press. reg? a bigger fuel rail?. and what adjustments should i make?..im not and dont plan on running any boost. any help, thoughts, or plain truth would be appreciated.
H22 Fuel Injectors Help!
go w/ stock ones again...
UNLESS you have BIIIG plans and have a friendly tuner that'll make a good running map for you w/ those big injectors, don't...
you car with 450cc injectors would run PIG RICH and be lucky if you can even get on your car hard w/o blowing black smoke all over the place and back-firing like a mo'fo'
THEN: 1993 Accord 10th Ann. Ed.---------------------- NOW: 1996 Accord EX
My Ride thread
Flickr
Originally posted by d112crzyAnd it can only get better. That's the best part.
All I gotta really say is:
People of cb7tuner, this AUTO is NOT a joke. It has impressed ME, the hater of auto's.
A stock or mildly modified H22 won't need bigger injectors, so go with the stock size. If you plan on going turbo (not a great idea on an H22, IMO), or some REALLY wild NA stuff (high compression, big cam, big bore, lots of headwork), then you'll need bigger...
More fuel doesn't mean more power. More fuel is just needed when you make more power.
