Car Stalls in Cold
    Car Stalls in Cold
    Stock 92 coupe lx 5spd
    A full tune up has been done. I cleaned the IACV, TB, and FITV. I couldn't clean the EGR because the bolts are stripped. It's usually fine just sitting there but if I start to go and then stop, for example, going into reverse and then stopping to go into 1st, the idle drops and if I don't give it gas it will stall.
    This is the second time today when my car has started in the cold and the idle has gone from 1k down to 200 and back up, then it stalled on me when I went to go from reverse to 1st.
    It has no problems once the car warms up. My guess is the EGR is fucked but I can't get the damn thing off either way! Even with pb blaster and air tools!
    Could it be something else or do I have to find a way to fix this EGR?
    If anyone has any ideas feel free to post, I'm open to anything.
      When you say a full tune-up, I am assuming you mean at least plugs, wires, cap, and rotor? Did you replace the fuel filter, air filter, pcv valve, and/or set the ign. timing? If you haven't you probably should, but either way here is some simple things you can mostly check yourself:
      - PCV valve (pull it off and shake it, if you can't here it rattle, you need to change it.)
      - Throttle body sludge (pull your intake boot off, and open throttle plate, if you see alot of gunk or even a little, clean it with some TB cleaner and a tooth brush.
      - EGR stuck (if you can get the bolts off)
      - Ign. timing
      - Throttle position sensor out of calibration
      - FIV out of adjustment
      - Leaking fuel injector(s)
      - Vacuum leaks
      - Intake Manifold leak
      I am sure there are many more things that can cause your concern, but I would Check the vacuum leaks, ign. timing, PCV valve, and Throttle body for sludge first. Good luck
      "I can imagine no more rewarding a career. And any man who may be asked in this century what he did to make his life worthwhile, I think I can respond with a good deal of pride and satisfaction: 'I served in the United States Navy." --President John F. Kennedy
      ASE Master Automotive Technician
      ASE Master Med/Heavy Truck Technician
      US Navy Electrician
      Contact me if you need help on the side.
      '92 Accord DX (For Sale)
      '01 Civic LX
      '00 Tahoe
      Greatest Rally Video Ever
        - PCV valve - working properly
        - Throttle body working properly
        - EGR stuck (if you can get the bolts off) I can't get the bolts off, even with an impact wrench and pb blaster, the bolts are pretty round now
        - Ign. timing I'll look into it.
        - Throttle position sensor out of calibration I'll look into it.
        - FIV out of adjustment working properly
        - Leaking fuel injector(s) I'll look into it.
        - Vacuum leaks I'll look into it.
        - Intake Manifold leak I'll look into it.
        My tune up conisted of:
        PCV valve
        SRI
        NGK Iridiums
        Wires
        Cap/Rotor
        Oil/filter
        Trans fluid
        Brake Fluid
        Brakes front/rear
        t-stat
        coolant flush
        radiator hoses
        valve cover gaskets
        fuel filter
        battery
        terminals
        cleaned IACV
        cleaned/adjusted FITV
        cleaned TB
        bled coolant
        radiator cap
        and probably more stuff I can't remember
          did you pull the intake hose off and look inside the throttle body? Just because it opens and closes, dosen't mean it is right...if there is any build up in there, it won't close all the way, causing idle problems.
          US Navy Electrician
          '01 Civic LX
          '00 Tahoe
            Yea I sprayed it with carb cleaner and cleaned it out.
              pull the intake. Start the car when cold.. Put your finger over the port in the tb. It should have suction while cold. No suction while warm. Make sure it completes that cycle.
                Sorry for jacking your thread man but when you guys say a "full tune up".
                What do you mean by a full tune up. I think i might need one.
                  Rotor
                  Cap
                  Spark Plugs
                  Spark Plug wire
                  Air filter
                  Fuel Filter
                  PCV valve
                  valve adjustment
                  check battery / terminals and engine grounds. Replace as necessary
                  oil change w/ filter if needed
                    Originally posted by ChIoVnIdCa
                    Rotor
                    Cap
                    Spark Plugs
                    Spark Plug wire
                    Air filter
                    Fuel Filter
                    PCV valve
                    valve adjustment
                    Where is the pcv vavle n fuel filter located?
                    Is that all for a full tune up?
                      Id suggest a manual... Valve cover and firewall.
