yo lastnight my clutch was soft. like it wouldnt come back up. the clutch wasnt hard anymore. i can start the car but cant put into gear. i also bought brake fluid. i did all of that bleedin it, and i got my brother to pump the clutch 3 times and hold it down and then releasin it. we did it bout like 30min? shit damn! clutch didnt pop back up
clutch
The clutch is not hard to replace. You just need to pull the transmission off (need a ball joint puller). You'll need a torque wrench to properly install the new components (I would just get a clutch, flywheel, and pressure plate all at once... and use a HONDA throwout bearing, not the one that comes with the clutch... they're all trash, even the "good" ones)
It sounds to me like an issue with your hydraulic system though. Might be time to change out your slave and master cylinders.
And are you putting brake fluid in your clutch reservoir?
Originally posted by deevergoteIt sounds to me like an issue with your hydraulic system though. Might be time to change out your slave and master cylinders."I'm a dude playing a dude, disguised as another dude"
"That if thou shalt confess with thy mouth the Lord Jesus, and shalt believe in thine heart that God hath raised him from the dead, thou shalt be saved."
Romans 10:9
><((((º>
from my personal experience i am willing to bet that you bled the clutch system improperly, you dont bleed the clutch system the same way you bleed the brakes, mainly because the clutch system is not supported by a booster like the brake system. constant pressure is necessary to the clutch system so i am pretty sure you messed up and let the clutch slave cylinder lose all pressure.
try this.....
fill your clutch master cylinder with clutch or brake fluid (hydraulic fluid is hydraulic fluid)then open the bleeder valve on the slave cylinder and pry the slave cylinder open while the the cap of the master cylinder is off. do this a couple times, each time just crack the bleeder valve open a little to let air escape then close it up and try the clutch pedal if you dont feel comfortable doing this then get a professional to do it, its not hard, just hard to explain. if i showed you, you'd be like OHHH.... DUH! but anyway try this first before you result to spending hundreds of dollars in clutch replacement, it might just be master or slave cylinder to but either way you need to have the system bled properly....
-seanMembers ride 15.927 @ 86.76 (f22a1)
Hit the clutch Hit the gear Hit the gas and i'm GONE>>>
Arcadia Green Crew #10
Mixing different brake fluid types can destroy your brake system. If you put DOT3 and a real DOT4 or DOT5 in the same system, problems will occur. This may or may not be true when mixing it with clutch fluid. It might be fine, it might not be.
Did the clutch work fine one day, and then start acting up the next? If so, then something failed.
If you've done something with the hydraulic system recently, then Sean is probably 100% correct in saying the system isn't bled properly. A little air in the system will result in exactly what you're saying.
If the clutch was bad, the pedal would still respond normally. It's definitely a hydraulic problem. Bleed the system properly. If that doesn't work, replace the master and slave cylinders (the "pumps"). You should probably do that anyway. The hard part about changing those things is bleeding the system. If you're going to go through the hassle of bleeding, might as well do it with new parts that won't fail on you anytime soon.
