throttle body
    throttle body
    throttle body would u get a aftermarket throttle body . and how much hp incress will u see
    I don't even understand what your asking my man.. but it's not worth spending hundreds of dollars on a throttle body. Depending on what motor you have, you would be best off getting the h23 intake manifold upgrade and if you really want to go the extra mile like I'm doing, send your throttle body out to maxbore and have them make the port a little wider.
      What mods do you have to take advantage of an enlarged throttle body. Maxbore can bore out your stock tb or you can go DH racing. Either way H23 prelude manifold is probably the cheapest easiest upgrade on the car. And as for gains dont expect much. It depends on setup and everything the only way is take your car to a dyno baseline it, put on the part and redyno and see what you get.
