p12 ecu with f22a6
    p12 ecu with f22a6
    Would the P12 ecu from a f22a1 out of a prelude s even work in the F22a6, i mean the f22a6 has the IAB's and the dual runner intake, just wondering i have heard that the p12 has more of a aggressive tune than the pt6, and prelude f221 is rated at 135, this is because of the ecu
    p12 is only used mostly on people with f22a1. Its pointless the a1 in the lude was rated at 145 and the accord a6 was 140. Pointless to swap ecu the way I see it.
      But thats like a base gain of 20 hp, no?
      Either they're not the same f22a1, or there's something to their ecu...
      How do they make more hp on the same engine?
        the prelude has a f22a1 identical to the ones in the cb7's the difference is the ecu, it has a p12 that has a more aggressive tune, i just want to know if i would see any gains putting this ecu on a f22a6
          more aggressive- what does that mean though?
          Simply adding more fuel, making it richer couldn't make 20 hp, if its stoich, air/fuel is already as good as its gonna get, right?
          If its getting more fuel it needs more air, so it would need more aggressive cams, or a significantly better IHE combo, and as far as I know, it doesn't, they're the same for all intents and purposes. The cam I don't know about though.
            the timing is advanced, idk im not for sure, but i did some research and this is what i came across, people have put the p12 in the f22a1 and felt a actually difference, research and you will see it too, i just didnt find my question answered so i posted it
              I'd be interested to hear if anyone runs one in their CB, would it even run right unless it was chipped and retuned?
                http://www.cb7tuner.com/vbb/showthre...ight=p12+f22a1
                read this thread and read what kingdave has to say about it and thomas LX
                  I wonder if its just mental, but the P12 may not do all the things needed in an accord, BUT if the tune is better, perhaps an accord ecu could be tuned using the preludes p12 map, so hopefully everything still works as it should, and the engine is bumped up as well.
                    thats what i was wondering too, i bet the p12's map could be used to help tune the accords ecu, by the way i am diggn your white cb, i am about ready to finish mine, got my clear corners and bumper signals, i am gonna white out all the trim tho
                      I kinda plan to do that myself, if I ever get this sucker repainted, which it desperately needs
                        im lucky my dad works at a ford body shop as a collision reparist, and is a damn good painter
                          How would he charge you for a complete recoat, multi-stage paint
                            Bowzil is running a p12.
                              he does all of his stuff on the side, he doesnt run it through his work, plus my aunt and uncle have a body shop, and hes about ready to quit and work out there full time
