how to
    how to
    how do i take out the a clutch pedal.
    i am trying to take it out of a prelude so i can use it on my swap but i cant get it there is a lot of glass everwere i got it lose i cant get it out know can some buddy give me step by step help
    You really have to get in there to get it out. You'll need the brake and gas pedals as well (well, the brake pedal, anyway... but they're usually in an assembly, no need to take it apart) The automatic brake pedal is larger than the manual one, and won't work with the clutch pedal as far as I know.
      you have to take apart the whole dash. i mean really take it all out. It will make it easier.
      '90 Accord EX(project)
      '88 CRX SI(DD)-SOLD
      '95 Prelude SIVTEC-SOLD
        Yes it might make it easier but that is just to much work.
        Ok when your under there you have to undo the 2 bolts on the firewall holding the pedal to it. Then you have to take out a little cotter pin holding in the rod going into the clutch master cylinder. That is the hard part, cause sometimes it does not want to cooperate. Then just jank it out. Well disconnect the plugs going to the top of the clutch pedal then pull it out. Its that easy.
          Ah yes... the memories of uslspct cursing as he tried to get that cotter pin out... I sold him the 5 speed parts cheap on the condition that he pulled them himself
