Cheap radiator
    Cheap radiator
    noticed it heating up recently on the way home from a job, pulled of at a gas station and noticed i was about out of water. i filled it up and dident notice any leaks, it seemed like the only drops were either from before the fill or my spilling during the fill. so i drove it to school the next day and it dident heat up but when i cam out of class i had a small puddel in front of my car. re toped it off and brought it home and put a preasure gauge to it. bad radiator to my dissappointment. is there somewhere that sells em cheap?
    thanks
    kyle
    1993 CB7 lx Coupe
    looking for maroon coupe door handles and a half nose bra and a bike rack for the roof, already have a *** trunk one, hook me up
    i got a new one at pepboys for 80 bucks. Thats the cheapest i found one.
      ebay
      Click Me
        thanks
        kyle
        well, to start.. I think you should start using radiator coolant in your radiator rather than water. Water has a lot lower boiling point than the coolant which would take care of your overheating. Also, when sitting.. water rusts my brother.
        after you replace a radiator and you have no coolant.. don't get me wrong water is the next best thing, but to run on primarily ater is a no no. good luck with your new radiator. it's like buying new brakes.. no one likes putting money into things that don't make there car drive like a rocket ship.
          id check hoses first, ive had some random leaks with my lower one before.
          id had to take it off and then reposition it with a new hose clamp.
            kinda.
            But if u wanan start adding things on to your motor and this and that. Whats the best aftermarket rad to use so your car will RUN cooler?
              I would say koyo. Check out www.passwordjdm.com I know they sell them; I was planning on picking one of these up myself.
                Originally posted by F20A CB7
                kinda.
                you run water and redline water wetter. it makes it run about 20 degrees cooler.
                if you want it to run even cooler, just run a lower temp thermostat.
                  x2 on that.
                  But i have no luck on the cooler thermostat. Can't find one anywhere
                    Originally posted by H23CB7
                    x2 on that.
                    napa has one for 170 degree and i believe f22parts has a 160 one.
                      awesome
                        I got a 160 from Advanced
                        MR Thread- I brought SEXY back- LOL
                        If it jams, force it. If it breaks, it needed replacement anyway.
                        Never argue with an idiot, they drag you down to their level and then beat you with with experience!!!
