excellent, i think this thread should be a sticky
How to make 30+hp for $500 or less... (DX/LX F22A1 only)
This topic is closed.
This is a sticky topic.
Then nobody would read it!
Honestly, aside from the F22A parts, there's not much science behind my claims. HondaFan81, who is VERY meticulous and accurate, has pointed that out to me. He's really busy, but I believe he'll soon be providing a bit more detail into bringing out the most performance for the least amount of money with the F22A.
Until then, I'm simply going on the stock numbers, and the differences between the engines. The extra airflow of the H plenum, as well as an improved intake and exhaust system, are very likely to produce more power. The reason why I have each modification limited to about 5hp at the crank is because I wanted to retain a fairly moderate claim. It may be more, it may be less.
Still, the principles are sound. None of the modifications I mentioned should require you to rev beyond the safe stock limits to make the most of the added power. Still, I have no concrete information. Just a reasonable understanding of how things work.
Originally posted by deevergoteDo you understand what you're suggesting?
i dont think he does
Originally posted by moey not just use the h23 ECU and bore out the h23 IM?
Originally posted by Shadow1i dont think he does
because these mods are for the f22a motor. not the h23. the intake manifold we can use comes from the h23, but its DOHC. not SOHC. if you plug an ECU from a DOHC motor to a SOHC then you may risk messing something up. the h23 may have(someone, once again, correct me if im wrong. lol) different timing and a/f ratios.
Whats the diff in exhuast mani between the a4 and others.
The a1 is a 4-1 design, and the a6 is 4-2-1 setup, wat about the A4, shes the same as 4-2-1?? some 1 correct me plz**Blk Housed Slut Crew Member #1**
Originally posted by Shadow1the f22a1 and a6 have the same headers. its the a4 that has a different set up and gives you a better gain in hp than the other 2.**Blk Housed Slut Crew Member #1**
This is a 100% false statement.
The A6 and the A4 share the same basic 4-2-1 header design, but the difference is in the way they are made. The A4's are constructed out of tubular steel, much like an aftermarket header, whereas the A6's upper half is cast. The lower half is the same on both cars.
In all honesty, I think this upgrade is worth less than 5HP, because it pretty much isn't detectable at all when driving the car. I think Honda simply switched to a cheaper construction method. I also think that part of the reason may be the fact that the 1.75" collector is probably more of a restriction on a bolt on accord than the upper half of the manifold is.
In all honesty, I think this upgrade is worth less than 5HP, because it pretty much isn't detectable at all when driving the car. I think Honda simply switched to a cheaper construction method. I also think that part of the reason may be the fact that the 1.75" collector is probably more of a restriction on a bolt on accord than the upper half of the manifold is.**Blk Housed Slut Crew Member #1**
