Problem 92 Accord
    Problem 92 Accord
    i have been taking a apart my motor trying to repalce my head gasket becasue i thought it blew....well i got to it and its fine....What else could it be................This all started with i noticed antifreeze inn my driveway alot of it it was almost empty. So i thought it was a hose so i replaced it. Couple days later did it again but now it was overheating very quickly...when driving it to my friend shop it just shut down after i shifted into 2nd. ..than hasnt started since
    did you ever do a pressure test? That should have given you the exact location of the leak...
    dont want to scare you, but the block might be cracked...
      Ya man i dont know why you would drive it.
      Should have had it towed.
      Id fear the worst. Inspect your motor very carefully.
        yea it was a bad move on my part.....but i didnt realize it was overheating till i was on my way to the shop. Might have to look for a new motor.
          Clean everything up and look for a leak. Dont jump to conclusions when it might be the gasket to the thermostat housing. Check all hoses for any cracks/leaks. Check temp sensors and make sure they are snug, check EVERYTHING before you jump to getting a new motor, from what i remember, you put alot of time into this one.
          90 Accord EX F22a1 Auto R.I.P.
          2011 Mazda 3 Hatch 2.5L GS sport HELLO!
            yea Im gonna look over everything. I did put alot of work into it so it would nice to not have to do a swap. It would prolly take me about a week to do the swap. I found a 1990 accord for $300 that needs a tranny. It has about 122,000 on it.
              would this cause it not to start?
                It should start no problem, but if the gasket is blown it could be pissin out rad fluid.
                  did you check the oil for coolant in it???
                  was there sluge in the head with the valve cover removed??
                  FS: DSM turbo parts,OEM parts, and more.....
                  My Members Ride Thread - R.i.P
                    yea i did....the oil had coolent in it .......and the coolent had oil in it
                      damn. just like mine. look in my member thread at my head with the sluge in it. i had overheating,flahing oil light.
                      customlowz is probally right like mine cracked block.
                        well i def need a new motor.........any one have a motor that that took out when doing a swap...i would love to do a vtech but to much $$$$ i just take another 2.2l
