Passanger Front Tire - noise
    My front passenger tire makes a noise once every revolution. It sounds like there is a piece of duct tape stuck to my tire. I've visually checked it many times. There pressure is fine, there is the same amount of play in the hubcap as every other hubcap. There was some stuff stuck in between a tread but I got it out with my key and the noise is still there. The tire appears fine.. thread is good.. what could this noise be? I've driven 500miles with the noise so it can't be too serious but it's annoying.
    Any Ideas?
    Thanks
    Tread.
    Anyway, sorry... I just found this. Check for abnormal wear. It could be tire scrub due to bad alignment. Mine does it as well, and that's my first thought. Next would be rotors or the wheel bearing... but those are less likely.
