Spark Plugs
    Spark Plugs
    I have previously written about this problem, although i was wondering if this could be a possibility, my car's engine has been stuttering when im at very low speed or at a stop point... my question is could it be that i need to change the spark plugs.... any advice will be really helpful
    Thanks
    Is your AC on whe it happens?? and does it happen evrytime you slow down or stop? Could be a dirty IAC Valve, If you havent done a tune up in the last 30 or sooner it is time cap rotor pugs Ohm out your wires and fuel filter. If i happens when your ac is on and not everytime you could have a bad Diode in your AC electical system
      would it be too difficult to take them out and examine the color and gap?
        I had the same problem. I'd sit still at a light, and it's miss every like..10 seconds. (mind it was at 1000rpms) Then, when I went to take off, it'd miss real bad. I just changed the spark plugs. It stopped the miss, and I changed the spark plug wires, and it sits at 800rpms perfectly now.
        -I used nkg's-
        98' Mustang 3V Swap
        11' VW CC R36
          your screen name, 3tc, what does that mean?
            Like said earlier if its been awhile just change the plugs, wires, cap, rotor. Mine kept shutting off when stopped and it ended up being a fried coil....
              My Honda is my Daily I race old school Cars I have a 81 TE71 Corolla which had a 3tc motor in it it was a Hemi Toyota motor with dual 44Mikunis and .510 lift cam which is where my screen name came from on all the forums i'm on it is the same I also have a 71 Datsun 510 that is getting resto right now and a 85 Toyota truck built 22r with dual 40 Webers and bagged on 18's
                jesus christ... GIVE US SOME PICS MAN! XD
                90 Accord EX F22a1 Auto R.I.P.
                2011 Mazda 3 Hatch 2.5L GS sport HELLO!
                  Alright I will start a post in beg photo gallery dont want to hijack this one to bad
                    http://www.cb7tuner.com/vbb/showthread.php?t=88062
