Vibration
    Vibration
    ok i got a 93 accord and when i put it into gear it vibrates..sometimes a lil rough sometimes its unnoticable..the idles fine it jus vibrates a lil then you give it gas and it stops and the car drives fine...what could this be???
    keepin it sohc!!!
    o and its auto.
    keepin it sohc!!!
      Motor Mounts. Loose suspension components.
      1996 Honda Civic LX 2009-2012
      2012 Kia Optima LX 2012-2013
        Can u feel it in the Steering wheel real bad?
          yea my steering wheel shakes real bad..i thought it may be the motor mounts were worn out or i need some new bushings..
          keepin it sohc!!!
            yeah check those.
              aight well i will get that checked out.
              thanks
              keepin it sohc!!!
                auto's are known to have bad rear mounts. check that solenoid next to the rear mount also. because it may be bad. there should be a rod that connects to the rear mount.
