Chipped Ecu and Dyno Tune
    Would i benefit from a chipped ecu if i plan on getting my car tuned on a dyno, would the chipped ecu be waste. I know i would benefit from a chipped ecu period, but since i want to have my car dyno tuned would the chipped ecu even help at all?
    The best way to get your car chipped is to tune it on a dyno. You would see how it behaves. What adjustments would make the most power. The program that will be written with a laptop on the dyno could then be burned onto a chip, and that would be your own custom chip which is 10 times better than a universal chip.
    My CB7 is now ***FOR SALE***
      what do you have done on the motor?? I doubt you would see any noticeable gains if the motor is stock, the factory tune is tuned to run the stock motor perfectly.
      1993 Accord EX
      2011 Subaru STi
        just cold air intake, as of now, just getting info, planing on doin' a 5 speed swap, and 272 delta with bisi header, some underdrive pulleys, all that good stuff, as of now just collecting info, research, research, research, learning everyday
