more whp/tq
    (also, with a modified F22A head PRIMOCB7 ran a 14.3 on drag radials The F22 has plenty of power to unlock!)
    that is really awesome. something that is very unexpected. hmm, sounds like a good idea.
      That was YEARS ago as well... I'm not positive, but it may have been before this site existed. Stupid Francis... keeping the potential of the F22 a secret...
      I think JG built the head completely for him. I don't believe he ever upgraded the bottom end (this is before I knew him, so the details are vague). There has never been a really good header for the F22 (until Bisi's comes out), and tuning options were probably limited (I doubt Francis had a P06, and I'm pretty sure he never had any sort of standalone). 14.3 with the well worked head, drag radials (probably the same ones I have in my basement ), and little else... Imagine what could be done with a head like that, high compression forged internals, LSD, a great header and intake manifold or ITBs, and a good tune...
      When I asked Bisi what his race motor would likely do in a 2600lb CB7, he calculated that about 11.3 would be possible. I've seen a VERY fast built turbo F22 run slightly slower than that! (granted, NONE of us are building Bisi's race motor... but that is, at the moment, what seems to be the ragged edge of the F22's potential)
        well, most of the power comes from a good flowing head and a nice cam. with higher compression pistons, that will make you run race gas and tuning is a must. that's why most people that don't have money, like me, tend to go street application. I have built a b18c bottom end with itr piston, and b16 head match ported, skunkworks camshaft, all motor, and it ran good with only 91 pump gas. He wanted to daily drive it, that is why we stuck with the itr pistons. the ecu was just a chipped ecu. then he wanted to turbo it (fucken dumb ass for turboing a high comp. motor) and after a few months with turbo, his shit got stolen. I must say though, that engine setup with the turbo was a killer still. not tuned he did 13.3 and the weather was over 100 degrees outside. he was only pushing about 6 or 7 psi.
          A proper tune up will do wonders
          -air filter
          -new spark plugs
          -fuel injectors
          -new fule pump
          -and so on.
          -if you have an old engine, try to stay away from "engine cleaners"
          once all this is done get the above mentioned turbo...
          DEVOTE
          FS: Lokuputha's Stuff
            Backpressure is NEVER good.
            WHOA!
            Totally wrong!
            Backpressure = Torque (to a point)
            The lack of backpressure casues extreme heat to build up in the intake maifold. Exhaust valves burn and no longer funtion.
            Take off your header and run the car for a while.....
            A stock exhaust will beat a cat-back off the line anyday
            My stock F22A1 whoops on B18's with their massive 2.5" exhausts
            Sure the 200hp of the B18 beats me in the high end, but Im all about the torque.
            Your man for wiring solutions!
            CB7Man's Coupe H22 Swap
            CB7Man's Sedan Resurrected From The Dead
