What PSI ??
    33ish. Proper inflation ftw! If your tires say like max inflation 40psi, fill em to like 30 and go drive hard to warm them up and check again and see what they're at. Just be below the max and your fine. 33 works for me. Anywhere around there is good.
      I agree.
        I try to keep mine around 32-35
          I ran my stock steelies at 32-35. After driving it would get to 37ish. If you notice you have a LOT of tread on the outside...but not so much on the middle of your tire...then you're running to high psi. If BOTH the outside treads on the tire are worn more than the middle...your psi is to low...and your mph will suck too. Course if only outside or only inside is worn...alignment is bad.
          ____
