going turbo need some help
    hey everybody i got a t25 turbo that came from a 99 gsx with low miles and no shaft play wastegate set at 8psi a modified evo manifold 440cc injectors a g2 inercooler all oil and coolent lines and i got a phearable.net ecu i got the hole turbo kit off ebay for 300 bucks besides the ecu ok my qustion is how much hp do u think i can make with my 93 accord ex f22a6 5spd and it has like 93000 miles i have a 90000 mile thing done to it like 2000 miles ago everything was good no oil leeks or nothing do u think it will greatly efect drivibility thanks guys
    93 EX COUPE, F22A6 turbo project
    http://www.cb7tuner.com/vbb/showthre...45#post1615845
    96 lexus sc300 DD
    http://www.cb7tuner.com/vbb/showthread.php?t=143563
    back from basic.... off to ait.... CB still being worked on i have mad plans for it .. sorry cant tell its on the hush hush for now but all i can say in somewhere around 500 hp soon to come..
    aall im gonna say is
    dont expect much with a t25
      Run the t25, install a new ignition system and tune accordingly. You should gain 30-40hp to the ground easily. Don't skimp on doing it right.
        the hell does he need a new igniton system for?^ dont listen to him
        id suggest atleast get a 14b...a t25 is very small..it runs out of breathe around lets say..4-5000 rpms maybe less...look over other members setups...see what they did..do a little research...yoiu can run the t25 but i wouldnt expect alot of power out of it..it want a turbo for shits and giggles for a dd..then i guess its fine
          Gee I don't know. A high current, long duration spark efficiently burns the air/fuel mixture in the cylinder. The benefits are more power, easier starting, great throttle response and increased mileage. Just a mere suggestion with obvious reasons.
            new igniton is NOT necessary
              stock honda ignitions have been proven to last far over what a T25 can push
              Formerly 91AccordExR33
              11.68 @ 127mph
              417whp/375wtq
              Sold: 8/2016
                They've been proven to be more than sufficient up to 400whp.
                I think you're #1 problem right now is the phearable "tune".
