STiff steering wheel
    Hey guys(and gals) the power steering in my moms 90 LX is a bit stiff, ive had my share of cb7s and the steering was soo light but this one is stiff. It had a leak in the winter and it ran dry but there was no signs of a leak, now its all topped up but its not using fluid but the god damn thing is stiff, not stiff to the point of having no p/s. do you guys think it might be the pump?
    what do you call 2 lebs in an accord?
    Organized Crime
    you deffinately fcked up the seals inside the pump when you ran it dry..
      how hard is the pump to switch out
      Organized Crime
        easy, take out the belt, and there are two bolts holding the pump onto the bracket.
          is it slow too? or just stiff?
          btw, has anyone replaced their rack and pinion (entire assembly)?
            I don't know what u mean by slow but Im gonna do it tomorrow I sure as hell hope its not the rack and pinion, im gonna go grab a pump from pick n pull tomorrow
            Organized Crime
              Steering doesn't slow down when the pump is busted... it just becomes more difficult. The rack is direct with the hydraulic power assist... I currently have no belt on my pump.. . not exactly easy to turn, but it's plenty responsive!
              It's most likely the seals, as said before. When you let such a thing run dry, the seals dry and crack. In a hydraulic system like the power steering setup, shot seals mean no power steering.
                if u want some xtra horses just get a manual rack n throw the pump away =]........well if it wasnt ur moms car
                  I don't think you can get an accord non-power steering rack, but you can just use your power rack with the ends looped.
                    mine was the rack that went bad...it was soo hard to steer.....
                    Retro!
                    Hater
                      What a fuckin piss off, I was soo sure it was the pump, replaced it with another one. Same shit, guess the rack is fucked
                      Organized Crime
                        feel the metal hose comming from the pump the bronze color one that turns into a hard rubber line...
                        put ur finger on it and if u feel it pulsating hard trhen its the pump...meaning the pump is pumping but the rack is resisting the flow causing more pressure.
                        Retro!
                        Hater
                          I THINK ITS THE POWER STEERING.TRY REFILLING IT.IF ITS NOT THAT IT MIGHT B THE RACK N PINION....I THINK THATS HOW ITS SPELLED
                            Did you come to that conclusion yourself, or did you read the thread? Because that's pretty much what has been said over and over again.
