Starter Problems/Car wont start
    hey i have a problem. my starter died on me (had to hit it with a bat),so later on that week it wouldnt start even wit the bat. so me n my dad bought a starter. me and my friend replaced it and wen we try crankin it, it wont start, im getin a spark at my negative battery terminal. and wen my lightz are on i turn the key n the lightz turn off. also wen i put a screwdriver at the solonoid it sound like the starter turns lol. im so lost
    no 1 is interested? .....
      sounds like there is a loose ground.
      if they are all tight then check all of your main fuses.
        probably a distributor problem.
        mine i think it was a solenoid (i think thats whats its called)next to the distribtor. well buy one if it not it return it back.
        also check your grounds seems like there's a short somewhere. hope this helps
          thx alot. i think my batery fuse is blown lol. btw wut ground are there. the battery/starter/alternator. wut else?
            i think you mean ''starter'' not ''distibruter''.
            and yes i already replaced mine
              try reseting ECU my dumb car needs to be reseted all the time now to start and idky. Disconnect the + or - cable of the battery for 3 seconds and connect it back. Make sure you ECU fuse is not blown too. Then try turning it on.
              1992 Honda Accord EX My Ride Thread H23A BLUE TOP Complete
                hmm ima try restarting the ecu but i left my lightz on doing some diagnotics lol dang
                  ouch.
