91/93 f22?
    91/93 f22?
    well i have a 93 se
    f series.. not sure what kind..
    its from a 91... theres the problem.
    when i got it the guy said 91 engine same as 1993 f22a6 or something idk if he actually said f22a6 but he did say same engine... but i look at the options and yeah confused. is there a way i can look at something on the engine to see what i gots or what. i would really like to know what i got. haha
    don't know which f series it is can someone help me. thanks!!
    Accord SE
    93se
    Members Ride
    Bought from: H22wagon93, Theos92VR4, Hondafan81, Father Time, DarkHusk, Gunrunner, FamousFreak
    Sold to: sulimed, BurtonRiderT6, tishock
    if its a 91 more likely is a F22A4. you can look next to the header to the left a plate.
      Thanks that helped alot... i looked by the head. it said F22A then the rest was smeared off haha.. but i have another question. if i wanted to drop in a F20b engine (the one with 200 i forget if its a or b) would i need a diff trans or could i use the same and would that be the best time to make it a stick..cuz then i would deff need a diff trans. oh and this is a dumb question but what makes a cb7. like i see yall talking about the ex and lx but no se like mine... well thanks again for all the help
      Accord SE
      93se
      Members Ride
        I'm not sure if you've been to a salvage yard or not but i've always wondered why on some of the engines, the engine code is missing. if it wasn't for the bumper lights and the sports button on the auto shifter i wouldn't be able to tell the difference between the Accords.
        You said yours was F22A if theres no numbers after that "A" that could be the Japanese engine that someone swapped in if you aren't the original owner. The F22A is comparable to our F22a6.
        You could always check to see what ECU you've got under the rug and post back here with it.
          where would i look again.. sry im a noob at this haha
          Accord SE
          93se
          Members Ride
            well i do know that its not the same engine that orginally came with it. and your saying that if its a A then its just like the one with a.
            and are you saying that a simple sport button is what makes the diff between a cb7 and non cb7
            Accord SE
            93se
            Members Ride
              just take a shop rag and spray some brake cleaner or engine degreaser on it, then clean the plate where the engine code is on the transmission housing.
              if you just see F22A then that's the Japanese engine.
              if you've got the auto transmission, the sports button just tells you what year car you might have because the sports button was removed on the 92/93 Accord. When we or anyone say CB7, that refers to the body style of our
              90-93 Honda Accord. if you ever see CB9 that's the station wagon version of the 90/93 Accord.
              sorry for any confusion. when i'm at the PnP i give the car a once over and to look for tell tale signs of which trim/year the Accord is before i look at the sticker on the rear quarter panel that tells me what i'm actually looking at.
              here just look at all these acronyms that this site made up..
              http://www.cb7tuner.com/vbb/showthre...ight=body+code
                yeah i gots a f22a4. oh well means im gonna just have to find a diff. what are the chances of a f20b fitting in there... or just a head swap.. do you know how much of a diff that would make
                like h22 head or f20 b head swap
                just a few ideas
                and thanks for the cb7 and 9 info haha i was confused at times
                Accord SE
                93se
                Members Ride
                  you wanna know what makes the difference between your a4 and the a6?
                  the intake manifold, ECU and the cameshaft.
                  keep your a4 exhaust manifold/header because it's the 4-2-1 ( flows from four ports to two pipes and then combines into one pipe) design that the aftermarket ones copied which is better than the a6's even.
                    ok so... a new intake. new ecu and new camshaft(all new performance parts)... would the new ecu have to be programed?(thats prob a duh) and i want to get dc headers and down pipe. that sould set me on my way to mild performance upgrades right haha
                    Accord SE
                    93se
                    Members Ride
                      what are you trying to acheieve?
                      for just a little beat around daily driver, a h23 or f22b is cheap and has a decent amount of torque espeically with those transmissions.
                        just a mild upgrade really. nothing to much
                        what would be better really swap or just parts.
                        Accord SE
                        93se
                        Members Ride
                          it took me longer to do a headswap than to swap the entire engine out. ill leave it at that...
                          just make sure you have all the parts necessary for a swap and you really shouldnt run into any problems.
                            well if ya put it like that...
                            i have a f22a4 and i guess i do kinda want to do a swap but if i stick with f series engins i shouldnt have to worry bout changing the trans right?
                            Accord SE
                            93se
                            Members Ride
