Oil Light Back!!! Tempature going up WTF?
    This only happens on long trips i drove from roanoke to martinsville and it didn't happen on the highway..but there was a traffic hold up and i had to stop the car..so the light was like kinda wanting to blink but it wasn't steady..
    only in neutral...but when in gear etc..it's fine
    also the temperature goes up ALOT idk what's wrong the radiator is filled..
    im going to drive it tonight for about 20 mins after i re-check all the fluids and shit..
    i'll update tonight thanks
    Ride: 2002 Lexus IS300
    Just swap in a H22
    wat?
      Oil Pressure sensor is faulty. For the temp , check for leaks somewhere , even to the slightest leak it will go up.. Or could be yout temp sensor is faulty also. Also the thermostat.
      1996 Honda Civic LX 2009-2012
      2012 Kia Optima LX 2012-2013
        all this temperature issue biznass and the condenser fan and rad fan both work?
          im thinkin thermostat and oil pressure sensor
            the rad fan works because i hear it at times
            probably some sensor
            but yeah
            it does turn on after i shut off the vehicle for a little bit
            idk why though
            maybe to cool it down
              Have you checked your oil lately?
              Your oil pump may also be failing. Oil provides around 20% of your car's total cooling.
                oil is at normal level
                maybe the pump is that costly?
                  Hey it's your thermostat it is getting stuck and it needs to be replaced,, I went through it about 2 months ago.. give it a try.
                    how much was it?
                    and the car get damage if i drive it like this?
                      okay i checked the coolant level in the radiator and it needed some...
                      but yeah i see the problem now
                      the coolant reservior is not passing the coolant through because you know
                      what the hose from the reservoir hooks up the radiator..near the cap
                      it's cracked and coolant spills out the little plastic thing
                      i think since it's not passing coolant it's using up alot of coolant in the radiator
                      and makes it overheat? an that's probaly why the oil light wanted to blink right?
                      opinions?
                        It might be coolant related. But that doesn't explain the oil pressure light.
                        You have to assume the light is working correctly until proven otherwise, otherwise you are probably going to lose the engine at some point.
                          yea it barely came on i mean wanted to come on but it faded away
                          and it wasn't steady though
                          but if i pressed the gas in neutral it went away
                          idk what's wrong with it
                            Try to get a new oil pressure sensor
                            wat?
                              you should definetly get a new pressure sending unit. they are not that expensive. also check your thermostat for sticking that may cause the overheating at idle. those are fairly inexpensive too. if the pressure sending unit doesnt fix the oil light it may be the oil pump. not so cheap. always try the cheap and easy stuff first.
