i really need some ones help please!!!
    i just got a F22B and well i dont know how to release the tension on the timing belt. i have a pic of what it looks like. in the pic the timing belt is off but only because i slowly pulled it off by hand to remove the head. if there is any one that has this swap and knows what to do or know of a link to a tread to help... please share. it would make things go alot smoother knowing how... thank you!! and can someone tell me ANY links to treads for all f22b dohc rebuilds or swap DIYs...
    92accord803
    well, im not too sure about your problem, but here's a swap FAQ/DIY for the F22B DOHC:
    http://cb7tuner.com/vbb/showthread.php?t=81303
    Originally posted by deevergote.
    And please, for the love of God, type like a human being!
      im not too sure but dont u just take off the spring, remove the metal restraining clip and remove the tensioner pulley? then just slide off the belt
      Hold On Not Done Accelerating
      Had One Never Did Again
        btw i luv ur drop.....coilovers?
          yeah.... coilover. with 18 inch wheels
          92accord803
            you should just loosen the bolt that holds the tensioner in place and give a little pull on the belt and it should be loose enough to take off. its basically the same as an F22ax.
            Originally posted by Devergote
            A CB7 with an H22, a clean paintjob, HIDs with a projector retrofit, some nice wheels, and a mild drop on H&R Sport springs and Koni Yellow shocks... that's the perfect car. I'd be happy with that for the rest of my life.
              okay, thanks. it just a bitch to take off right now...
              92accord803
