Unichip!!!
    Unichip!!!
    check it out is it too good to be true?do u all think this deal is legit?
    http://www.sfxperformance.com/parts/UNIREPROGRAM.htm
    Yes it is too good too be true, those things are bunk, they will make your car run very rich.
      It is installed in the garbage.
      Chipped ECU is the way to go.
      1996 Honda Civic LX 2009-2012
      2012 Kia Optima LX 2012-2013
        foreals?how can i do that?b specific please im a noob.
          so in other words make my car run very rich means its good to get one?
            Chipped ECU is like a hacked ECU , realeasing it's potential. However , you do not need a chipped ECU unless your car is loaded with engine performance.
              oh and does it make alot of differ if i get a chipped ecu?i was thinking of getting an ecu off of a 92 to 93 accord ex f22a6 and put it on my honda accord 90 lx f22a1
                what if i still want one?i only have a exhaust knn and spark plug wires
                  On a stock car chipped ECU is not recommended. If you are plannin on building your engine , a chipped ECU will be a good investment.
                  Swapping factory CB7 ECU's won't give you performance gains.
                    yea im planning on building up my engine.so should i get one?
                    and maybe not performance but it will remove my top speed limiter right?
                      Yes. It will also let you tune a better basemap.
                      To learn more about ECU Tuning , go here http://www.cb7tuner.com/vbb/forumdisplay.php?f=111
                      every info you need is there.
                        yes to which question?
                          Both.
                            oh ok thats tight.well im definately going for the new ecu.if i change my ecu can i still chip the new ecu?
                              You can chip any ECU I think. If you know how that is.
