i need help please ,i just broke my driver side upper controll arm ball joint,can some 1 show me how to replace the uupper balljoint ,and tell me what tools i need 4 the job or i need the whole upper controll arm thank u guys
replacing upper controll arm balljoint
shop around before using rockauto...the handling is going to run you a hella lot of money.
I was looking at getting a corner light after a deer impact...rock auto price was something like $12 but with shipping and handling it ended up being cheaper to buy through autozone. Like 20-30.
I found this to be the common trend with online purchasing. I found a set of lights for 11 dollars...but with shipping and handling it was near 40!
So ask around the local auto stores...also...check junk yards. I had to replace a control arm right after I bought my 240 (buy 'em broke...get 'em cheap ), got one for cheap out of a yard. Of course it'll have wear and tear, but if you just need a replacement, you can't do too bad.
Personally I need new ball joints before I get an alignment...but I will most likely use oreilly auto or autozone. Online handling is too high for it to be worth it...even when you're in a pinch.____
