say i buy a shot ram or cold air for my dying f22.....it should work with my h22 swap too correct? i didnt see any hybrid intakes, so i figured it wasnt a problem.
quick intake question...
Originally posted by C91BLX7H22 ones are bigger because the tb is bigger
ive always used a cold air on my 2 d series, but short ram on my b swap. i used a short ram cause i didnt want too buy a short ram. granted heat wasnt really and issue. under the hood of my cb7 is ungodly hot, so i think ima run a cold air.
Most aftermarket people do 2.5" for accords for our gen...Ebay its a hit and miss with a 2.5 or 3. Usually its a 3 which is what I got for my accord so it fit the tb just fine. And as mentioned the accord intake will fit because well the c urvature os for an accord.
Originally posted by NAiL05Most aftermarket people do 2.5" for accords for our gen...Ebay its a hit and miss with a 2.5 or 3. Usually its a 3 which is what I got for my accord so it fit the tb just fine. And as mentioned the accord intake will fit because well the c urvature os for an accord.
If u are getting a short ram, why not just pull out the stock airbox and replace it with a good cone filter....the OEM intake tubes are usually tapered and they tend to have pretty good flow characteristics; not to mention good heat insulation compared to the aluminum tubes.DEVOTE
FS: Lokuputha's Stuff
Originally posted by lokuputhaIf u are getting a short ram, why not just pull out the stock airbox and replace it with a good cone filter....the OEM intake tubes are usually tapered and they tend to have pretty good flow characteristics; not to mention good heat insulation compared to the aluminum tubes.
