Please Help!!
    Please Help!!
    i have a 1992 accord lx f22 a,,,i cant get spark,,i replaced the ignition control module,ignition coil,distributor cap,distributor rotor,new ngk plugs and wires,and still nothin my baby wont start help me someone please!
    You posted the same thing 5 minutes apart in 2 threads. Why should anyone help you? You're rude.
    Perhaps the coil or igniter are bad. Just because you replaced them doesn't mean they work. Start with those. Then work on the other parts. Something you replaced probably isn't working correctly.
      check your grounds
        hows your battery? your starter?
