balance shaft eliminator
    okay so i already did SOME research on these, but i cant seem to find ....about how much HP gain? can someone explain why more oil pressure would = more HP?
    u dont get more power from increased oil pressure u get more power because the motor no longer has to spin the balance shaft....as far as gains i think i read on honda-tech that someone gained around 2.7 whp on an h22 by eliminating balance shaft belt.
    My Members Ride Thread
      i dont use my balance shaft belt either, but if you look at engine builds like hondafan81 those guys will tell you you dont gain any power until you eliminate the shaft itself
        you gain oil pressure from the plugs that redirect the oil flow. you gain the power by getting rid of the parasitic loss from the balancer shafts. i think the gain kaizen speed listed was around 15hp (thats with the kit kaizen speed sells).
