will my upper control arms get in the way when i lower my car?
    the rear upper control arms look kinda close to the tire and im worried that if i lower my car, the control arm will start rubbing against the tire.
    i heard that if i lower my car, the upper control arm will "move" and it won't be an issue, is this true?
    will i need to make any modifications to the control arm?
    MY CB7
    FULL part out thread:
    http://www.cb7tuner.com/vbb/showthread.php?t=204494
    it wont be any closer or further. the only problem that may concern you at this moment is if the control arm will hit the top of the wheel well.
    (129)Transactions and counting
      so how low does my car have to be in order for the control arm to hit the top of the wheel well?
      MY CB7
        I lowered my accord 3 inches. The rear upper control arms never hit. Its the front ones that will just beat the crap out of the car. Full metal on metal smacking, loud. I had to buy a camber kit. SPC is what I went with. Came with 2 new rear upper control arms. 2 adjustable front upper balljoints.
        Then plan on getting an alignment.
        I think there are bumpers you can get for the upper front arms. To reduce the metal on metal contact.
        buy my shit
          I hit front uppers with a 1.8" drop... It does it more when the camber is corrected. accordtunerx recommended that you leave 1 degree of negative camber to avoid that.
          I smack my rear uppers all the time with my H&R Race springs. I have yet to invest in a rear camber kit, but I'm probably going to have to.
            oversized tyres?
            bros, my car came with 16inchers that have tyres that are overspeced.
            It's basically 205/60 R16 now so my speedo's about 6% too slow.
            Is it because of that that's why at the rear wheel well the tyres look like they're about to scrape the control arms?
            Should I revert to the 'oem spec' 205/50 R16 (based on those tyre calculators) the next time I change my tyres? I don't mind the harsher ride because, I've never cornered so confidently before! HEHHEHHEH...
            My previous rides were a Nissan Sentra on 14inchers and a Toyota Soluna (Tercel) on 13inchers (HAH)....
            Pls advise.
            Thanks!
            Btw: my ride's mileage
            It's a non-VTEC F20A5 SOHC PGM-FI. max power 130PS@5500rpm. max torque 18.1kgm@4500rpm when it was new. Engine swaps are so no-no legal in Singapore
              Having a taller tire profile could definitely increase the risk of rubbing. Still, it shouldn't... the arm moves with the assembly that holds the wheel, so when the wheel/tire moves up, the arm goes with it. If it's not touching all the time, it shouldn't ever touch any of the time unless you bend something!
              Have a fat friend or two put their weight on your fender and see what happens. (seriously... fat friends are great tools to have! A fat guy was very useful in changing my suspension... sadly, that fat guy was me... )
