f22-h23 swap
    f22-h23 swap
    could sum1 please explain 2 me everything u gotta do in order 2 swap out a f22a1 in a 92 accord lx and drop in a preluce h23 motor. i need like step by step because something jus aint workin right. cant figure out if itz ecu or wireing or what.
    no. but if you use the old ecu there should not be any wiring issues. which ecu are you using?
      Its like any other swap you and you need to wire in a knock sensor. You should be using a p14. Its all in the swap faq dropping it in is the same as an h22 just less wiring.
