My Cb7 Messed Up Today!!!
    Originally posted by Lroy onDA scene
    i have an outo
    Do you possibable think the tranny is going bad whens the last time you check or changed fluid?
      thats true when your going slow is the engine revving high (vroom vroom). the little needle to the left (closest to the door) does that go really high even when you arent moving fast? you could have a transmission problem in that case and its not shifting out of a lower gear. you can max out a gear and not go fast and do damage to the engine.
        Shifting on a auto tranny can mess the tranny up, since auto tranny aren't meant for high reving.
        1992 Honda Accord EX My Ride Thread H23A BLUE TOP Complete
          this guy im not that much of a noob to not know what rpm is.but yea thanks for trying to help.idk u all can forget about this thread.ill have it checked tomorrow.thanks everyone
            Check your fuel pump. when you over revved it you might have messed up your fuel pump and it tried to die on you because it wasn't getting enough gas. with the fuel pump messed up it wont get enough gas to go faster when you floor it either.
            Accords Rock!
            My Ride!
              I would say part of the reason no one can help you diagnose your car is due to the fact you are not speaking/typing in proper English. You might have better results if you take more time explaining the problems and less of the "vroom vroom" examples. I am not trying to bash you I am just explaining a way to receive better feedback.
                ....or just post a video up of how your car is driving and let it speak for itself, pictures > words in some cases and this might help you fix your car faster without all the other unecessary comments.
                member's ride thread
                91 Accord SE 176k
                  Originally posted by Alex13mod
                  check all cables in motor and coolant lines and fuses.
                  yea u were correct man it was one of the cables that came loose
