Using The Hand Brake!
    does it fuck up after u use it alot?and do your tires still waste if u use it in gravel?
    your hand brake manually controls your rear brakes. So by "using it alot"...as in ripping it up around corners to screech around em and impress da ladies, then yes I can imagine you will need to adjust it after a while. But if you do what I do, which is just put i on whenever I park and shut my car off, then it'll last forever and ever.
    ^^click it or ticket^^
      so what about the tires?do they waste if i use them on gravel?
        you mean like driving on gravel and ripping the e brake or just driving on gravel period?
          I would imagine ripping the e-brake like some pro drifter would stretch the cables over time since they aren't really designed for "drift action".
          ...adjust accordingly
            gravel then using the e brake
              for what...trying to make it slide...
              also are you using it to do burn outs....since it only stops the rear wheels...if so ...I would imaging after a while yeah that will wear it down...lol
              Nitrous is like a hot chick with a STD..... you know you wanna hit it, but you are afraid of the consequences.....
              ...Zex wet kit, 65 shot, dual purge, JDM H22...pure sex! .....I owned 8 CB7's in one year...top that JARHEAD...lol
              ...this thread has been graced by the new CB7 King
                now why in gods green earth would you want to drift on gravel lol
                UNDERGROUND SOCIETY
                NEW COUPE MEMBERS RIDE THREAD COMMING SOON
                  just so it can slide on gravel
                    haha....get a Nissan 240 dude
                      you don't need the e-brake to slide on gravel
                      Originally posted by Devergote
                      A CB7 with an H22, a clean paintjob, HIDs with a projector retrofit, some nice wheels, and a mild drop on H&R Sport springs and Koni Yellow shocks... that's the perfect car. I'd be happy with that for the rest of my life.
                        yo nice fuckin cb7
                          yea u do cuz if not u wont make a sharp turn cuz cb7s are from wheel drive
                            if you anticipate the turn then you don't need it because all you need to do is whip it in the turn and hard and go !! it takes practice !!!
                            listen.. if you are into sliding around and stuff... find yourself a big wide open field and got at it... the dirt won't hurt the tires no where near as bad as gravel or pavement. learn in a field how to control your vehicle.
                              lol.. the ebrake will loosen itself over time if you "drift" your cb7. But I recommend only using the ebrake when you are parked. You can easily snap the cable and lock the rear brakes if you pull too hard/too fast. Trust me, I've done it before, lol.
